Will not Accelerate just Idles
I Have Changed out the Lp Regulator / Changed spark plugs and wires Also new Distributor cap and rotor. Also tried other Distributor from other lift. Remove the Butter fly from the Governor. To make sure it was not closing off. Also Clean out the Throttle Body. Also check the Injector under Throttle Body. it still does the same thing. Also checked the Timing. CAN SOME ONE HELP PLEASE.
  • Posted 20 Jun 2025 06:32
  • By Rat1
  • joined 6 Apr'19 - 12 messages
Hi Guys Just letting you know that we did check out the Hyd control Valve and notice that my guy had Hooked the pressure line to the lift valve and the other Hose where the Main line goes. Changed them around and now the Engine Runs like it should.. Thanks for All the Help and Have a Happy Fourth and Be Safe.
  • Posted 3 Jul 2025 23:01
  • By Rat1
Hi and Thanks for all the Suggestions But this Lift has a Throttle cable all the way back to the Carb and does not have any sensor on it. and no we did not check to see if the Hyd is Dead heading. we will check that out and let you know. Thanks Guys
  • Posted 2 Jul 2025 03:10
  • By Rat1
Look at your accelerator pot for damaged wiring as well. should be 5 volts going to pot and the throttle body also look at your hyd control valve closely to insure you did not catch or damage any wiring inspect all areas you were in when replacing control valve make sure accelerator pot is plugged in tight
  • Posted 2 Jul 2025 02:34
  • By John_Bradley
  • joined 10 Aug'22 - 264 messages
Jb69
I read all the post you said you changed out the hyd control valve and then this started are you sure the control valve is not dead heading this would make the truck not take the gas and run with low ideal.
  • Posted 2 Jul 2025 02:18
  • By Scott_
  • joined 16 May'21 - 316 messages
Scott
Do you have IFAK Cable with PCST to Diagnosis
  • Posted 1 Jul 2025 15:05
  • By Dil_Era
  • joined 30 Jun'25 - 36 messages
dilshanrandeep@gmail.com
We did not jump nothing out we just keep cranking on it until it started. But also if you pull the fuel line off the throttle body it will still Run? and the LP Regulator is New.
  • Posted 1 Jul 2025 06:34
  • By Rat1
When you say you got it to run , how did you do that. ? If you jumped around anything then it is not going through the ecm and will not accelerate
  • Posted 1 Jul 2025 04:54
  • By John_Bradley
Jb69
This Forklift Does have a ECU that is under the Air Cleaner. We pulled it out and tried it on another Lift and that lift Runs good. the Model of this Lift is a GLC050RG Does not have any lights coming on when the Motor is Running. And yes the Lift was Running find when we Changed out the Hyd Control Valve and than it would not start and run. now we can get to Run but will not Accelerate?
  • Posted 1 Jul 2025 04:00
  • By Rat1
Sometimes it will flash a code ie: on dash a light will flash you count them
Does this unit have a SECM?
It is an engine controller
If so then you may need a laptop or code reader to get code
A malfunctioning temp sensor or a malfunctioning oil pressure switch or low oil will trigger it did it accelerate before? If so did engine rev up ?
  • Posted 21 Jun 2025 08:26
  • Modified 21 Jun 2025 08:28 by poster
  • By John_Bradley
Jb69
How can you tell if it has a code? it's not showing nothing on the dash. The S/N on this lift is E187V23265B. It has a Mazda 2.0 in it. Thanks
  • Posted 21 Jun 2025 05:30
  • By Rat1
Sounds like it is in limp home mode
If so should have a fault code stored
  • Posted 21 Jun 2025 01:30
  • By John_Bradley
Jb69
Elwell-Parker ESI500-36
JLG G12-55A
Oxford Ct, United States
JLG G12-55A
JLG G12-55A
