No spark P04 & F04 Need wiring diagram
Hi Guys,
Got a Nissan in with no spark. It has a K21 EFI engine dual fuel. We replaced both cam & crank sensors and short (Y) loom as well. Cleared all codes through dash, rotated and tested relays in both relay boxes, checked fuses and fuse box. Checked connection at ECM and VCM. Removed earth points on chassis and retightened.
Still has P04 & F04 codes coming up.
Dose anyone have a full wiring diagram so I can check all of the wires?
Any Ideas as I see that this has happened before but there is no real answers on the forum.
History is they drove it and parked it up for the night and next morning it would not start.
Thanks for any help and suggestions.
  • Posted 13 Jun 2025 10:12
  • By mrforklift
  • joined 10 Aug'09 - 39 messages
  • Queensland, Australia
forkliftrepairs at dodo dot com dot au
Only those 2 codes come up and wiring at relay box and box in really good condition.
  • Posted 27 Jun 2025 08:54
  • By mrforklift
Yes the MIL light is working
  • Posted 27 Jun 2025 08:52
  • By mrforklift
Those are communication codes
By the way I have seen e-27 code with a weak or bad coil assy
I would remove the left step cover and check
The main harness plug there are also relays there
  • Posted 27 Jun 2025 04:03
  • By John_Bradley
  • joined 10 Aug'22 - 265 messages
Jb69
No I have not. I do know for certain that the ECM part numbers have to match up with each other. I'm not sure how or if another brand of lift would be compatible with your Nissan. Plus it would have to be for a dual fuel unit also. Usually a bad cam or crankshaft sensor will throw a E-27 or a E-28 code on the dash panel. Did you have any of these types of codes? Had one that the wiring plugs on the ECM were not making a good connection in the ECM. Had another one that had corroded wires on the bottom of the relay box under the foot panel. Seems very strange that it was running the day before and then it doesn't have any spark the next day. What codes were on it to start with? Another question I have is the MIL light coming on when you turn the key on without cranking over the motor? If it does not light up and the bulb is bad then it will not start also. Thats what I learned in Nissan service school but never had it happen ever.
  • Posted 19 Jun 2025 12:59
  • Modified 19 Jun 2025 13:11 by poster
  • By mwjago
  • joined 20 Apr'25 - 15 messages
  • Montana, United States
mwjago
Hi thanks for your reply,
I have checked the yellow diode as we have had trouble with them before. I will check the voltages. Have you ever tried to swap EFI Nissan ECM with EFI Mitsubishi ECM ?
  • Posted 19 Jun 2025 10:28
  • By mrforklift
A Nissan wiring diagram is truly impossible to read. A few things to check are the QGS/other fuse, the ignition diode that is located inside the frame located behind the lower relay box. Some were a chocolate brown color or could be yellow in color and attached to the main wiring harness. One of our customers found a wire in a harness that rubbed through against the fuel rail and was shorting out. Your plugs on the coils should have a ground, battery voltage, and 2 volts while cranking the engine over on the signal wire then it drops to 1 volt while running. I would also use an analog type voltage meter to test it if you have one available. Check these out and hopefully you can locate the problem.
  • Posted 18 Jun 2025 14:09
  • By mwjago
mwjago
