Error Code FE32
Looking for some advise on what this error actually means. On the FE units it relates to overheating of hydraulic Fluid but I think it means something else on the EK units.
Any help or advice appreciated.
  • Posted 10 Jun 2025 18:05
  • By Mark_Gregory
  • joined 10 Jun'25 - 1 message
  • United Kingdom
Hi Mark,
Assuming these are the same as the OM XOP trucks (man up order picker). Can't tell you anything else as never worked on one....
FE32 "Height error"
Description - Monitoring of height measurement system.
Reaction: Reduced travel and lifting speed.
Cause: - Digital height is outside themonitoring window (±0.5V) for the analogue value.
- Lifting/loweringmovement without activated movement.
Lifting/lowering movement too fast.
- No pulses although movement activated.
Rectification: - Reset by turning the truck off and then on again.
- Check height measuring system, wiring.
- Teach in height measuring system.
Good luck.
  • Posted 13 Jun 2025 02:01
  • By Dez_A
  • joined 3 Jun'04 - 84 messages
  • Middlesex, United Kingdom
Service life of a forklift is proportional to how well it is maintained.
Combilift Ltd
