nichiyu fb15
good morning I have a nichiyu fb15 forklift I have a problem the trolley moves forward slowly while in reverse it works correctly.
  • Posted 10 May 2025 18:13
  • By Lucky51968
  • joined 10 May'25 - 1 message
  • Italy
gian luca
sounds like a contactor fault the contactors are double sided when one contactor operates the other contactor is closed and relies on the tip on the back of it to make a circuit so if it is not sitting correctly you will get that problem i have also found in he past that the reason for this is the bottom of the contactor assembly
where it pivots wears and doesnt sit properly solution is to change the contactor assembly they come as a pair hope this helps good luck
  • Posted 12 May 2025 20:09
  • By skyreach
  • joined 2 Apr'22 - 40 messages
  • Victoria, Australia
reach for the sky
Michel Denis Michel Denis
Linde C4230TL5
Unicarriers FD80-2
