Anti-Stall code 524226-4
When this code is present is it normally just a bad anti-stall coil or are there typically other issues? Also where might this be located?
  • Posted 9 Apr 2025 22:11
  • By Zeeker
  • joined 9 Apr'25 - 2 messages
  • Arkansas, United States
Thanks!
Zeeker,
The anti-stall solenoid is not getting the correct voltage or is shorted internally. Using a VOM on ohms, check wire 702B against battery negative, should read infinity, anything else is a shorted wire. Check across the solenoid pin connections, should read 5 to 7 ohms. If you read lower, coil is shorted, higher coil has internal failure. Once you get the problem resolved, code will no longer show on the dash. Good Luck.
  • Posted 14 Apr 2025 22:39
  • By Fishmech
  • Virginia, United States
ROYPOW
Muncie, IN, United States
JLG G12-55A
UN Forklift FD15-18T
