Crank No Start
Doosan D35S-5 with an inline 4 diesel forklift will crank and won't start, if you put a shot of ether in it, it will fire up and run with 0 problems. I feel as if something is telling the injectors not to fire as they are electronically fired. I have ordered a new crank and cam sensor. I pulled an injector turned it around hooked it back up and they are not spraying on crank. I do not have any way to scan the codes if anyone has any insight on what I need to do that I would appreciate it as it will likely lead me in the right direction. Any help appreciated thank you
  • Posted 2 Apr 2025 07:46
  • By RickDozer
  • joined 2 Apr'25 - 1 message
  • Iowa, United States
Hi, As far as I understand, the forklift has a Hyundai D439 engine. In order to understand the fault with the engine, you need to connect the G-Scan diagnostic tool to the forklift.
  • Posted 29 Jun 2025 04:52
  • Modified 30 Jun 2025 10:14 by administrator
  • By marksmith
  • joined 26 May'25 - 17 messages
  • United Kingdom
forkliftmanual.com
Sue Tomic Sue Tomic
