Engine identification and specs
I just bought a 1999 Hyster H30XM. Serial number starts with D001. Pretty clean little truck, and easier to haul than my bigger ones. I've done a good amount of net searching, and I'm not coming up with much on the engine. I know it's a Mazda, but what model would it be, and possibly what cars used it? Just looking for tune-up parts, valve cover gasket, and valve clearance specs. Thanks
  • Posted 25 Mar 2025 12:35
  • By Kevin_Bergman
  • joined 17 Sep'20 - 4 messages
  • Illinois, United States
Thank you for your help!
  • Posted 26 Mar 2025 03:14
  • By Kevin_Bergman
The truck had a Mazda 2.0 called fe or 2.2 f2 engine they were the same engine with a longer stroke the valve adjustment were with a hot engine intake and exhaust 0.012 be careful when adjusting the rocker arms had tappet **** when adjusting sometimes the ball would turn make sure it is one the flat side when you are adjusting.as far as tune up parts you should be able to get them on the net. The only truck that l think it was used on was around 1986 Mazda 626.hope l was of help.note in metric it is 0.30mm
  • Posted 26 Mar 2025 01:07
  • Modified 26 Mar 2025 01:09 by poster
  • By Scott_
Scott
Unicarriers FD80-2
SMV (Konecranes) 20-1200B
