No fuel after battery lead replace.
Good day,
I have a Toyota 42-5FG25 (S/N: 405FGU25-78696) with a 4Y engine under the hood. It's running LPG.
Due to corrosion, I had to run a new positive cable from the battery to the starter. After doing so the relay that controls the fuel lock-off (The odd little cylindrical one behind the battery) is no longer getting powered when the ignition is activated. If I power the lock-off directly, the truck starts and runs without issue.
I will mention that there are two additional leads coming off the positive terminal; one of which goes to the loom behind the battery but is energized as far as I can check. The other lead goes to the instrument cluster on the steering wheel column.
I, unfortunately, do not have an electrical wiring diagram for this machine, I wanted to see if anyone had any ideas as to what might have happened.
Thanks in advance!
  • Posted 14 Mar 2025 01:15
  • By Br455Brute
  • joined 30 Nov'24 - 9 messages
  • Alberta, Canada
Might have a fuse able wire one of the 2 little wires or check connection on plug by battery. Had a issue like that several years ago
  • Posted 14 Mar 2025 06:42
  • By Dave2013
  • joined 10 Jan'13 - 20 messages
  • Oklahoma, United States
UN Forklift FB25N1QZ1
Mitsubishi FGE35AT
Lift Technologies Inc.
