flashing lights
pwr red light, chg yellow light, chd green light, all flashing three times over and over.
  • Posted 19 Jan 2025 23:07
  • By Rick_Gotuzzo
  • joined 30 Aug'24 - 3 messages
Rick Gotuzzo
Rick,
Sounds like you are looking at the A/C connection for the charger. If the charger loses connection to this plug or the battery is below charger minimum, the lights will flash. Check your battery voltage first. Should not be below 24 volts. Fully charged voltage should read 26.5 to 27.5 volts depending on age. Should batteries read below 21 volts, may need to use a portable charger to raise voltage high enough for charger to read. Good Luck.
  • Posted 21 Jan 2025 04:46
  • By Fishmech
  • Virginia, United States
Taylor TT300
JCB 533-105
Oxford Ct, United States
Esie Cortez Esie Cortez
Taylor TT300
JCB 533-105
Taylor TT300
JCB 533-105
Zhejiang UN Forklift Co., Ltd
