wont turn on
1999 electric flt. Ignition will come on but then wont turn on and a spanner light shows. Two codes/numbers that come up are 00450 and 16. Cant seem to find out what they represent or mean. The truck was parked up and put on charge and then would move when we came back to it.
Any help would be appreciated!
  • Posted 13 Jan 2025 20:24
  • By james_james
  • joined 13 Jan'25 - 2 messages
  • United Kingdom
Thank you very much for your reply mate, ill take a look.
  • Posted 14 Jan 2025 17:00
  • By james_james
  • United Kingdom
James,
Verify the correct battery charger was connected to the lift. Code 16 is for battery volts to high. Not able to find a code for 00450. Good Luck.
  • Posted 14 Jan 2025 02:01
  • By Fishmech
  • Virginia, United States
Toyota 02-8FD25
Terberg YT220
Oxford Ct, United States
