Error code intermittent 523524-3
Need some advice
  • Posted 12 Dec 2024 02:23
  • By Gusstone
  • joined 17 Apr'20 - 25 messages
523524-3 is usually tied to a fuel injector circuit fault. As Jose mentioned, check each injector connector and the ECU plug for corrosion or loose pins-disconnect/reconnect to clean contacts. If everything looks good, trace the harness for damage, as intermittent shorts or breaks can trigger that code
  • Posted 11 Aug 2025 17:09
  • By Asjad_Khan
  • joined 10 Aug'25 - 5 messages
  • United Arab Emirates
KUBOTA 3.8L DIESEL TURBO
  • Posted 11 Aug 2025 08:30
  • By Jose_alvarardo
  • joined 9 Aug'24 - 2 messages
Jose alvarado
Gus,
Remove each injector connector and inspect for corrosion. Do the same for the ECU connector 204. Remove and inspect for corrosion. I would slide the connectors on and off to ensure a good connection. The only other problem would be a failing wire harness. Good Luck.
  • Posted 17 Dec 2024 00:00
  • By Fishmech
  • Virginia, United States
Which engine is installed in the truck?
  • Posted 13 Dec 2024 00:37
  • By Slim99
  • joined 13 Dec'24 - 3 messages
edition #1250 - 2 October 2025
Rob Ott Rob Ott
Executive vice president and chief commercial officer, East Penn Manufacturing
President, Logistics UK
Director of dealer development East Coast, Big Joe Forklifts
Vice president, customer, TVH Americas
Taylor T650L
Hangcha CPYD32XW71F-C
Flesherton, Ontario, Canada
Philadelphia, United States
Dayton OH/Cincinnati OH, United States
Prospect CT, United States
ASSET FINANCE
Nov 2025
