Error codes
This truck is showing the wrench symbol but I don't know how to find where it shows any kind of code. Is there a way to find this on the screen so I can troubleshoot why it is lighting up? The truck seems to be running fine so far.
  • Posted 12 Nov 2024 01:13
  • By tg0486
  • joined 29 Jul'17 - 78 messages
  • Missouri, United States
tg0,
Try this and see what you find.
190-4 Symptoms
Cranks
No Start
No RPMS
Replace Crank Sensor**
**Check air gap on Kubota diesel engines prior to replacing crank sensor
190-8 Symptoms
Cranks
No Start
No RPMS
Check Cam Reluctor Wheel installion/orientation
Check Cam Sensor - Cam Reluctor Wheel air gap
Check Timing Belt for damage or missing teeth
  • Posted 19 Nov 2024 03:32
  • By Fishmech
  • Virginia, United States
TG0,
What size engine do you have in the lift? I can provide steps for troubleshooting. Serial number would help.
  • Posted 18 Nov 2024 23:46
  • By Fishmech
Camshaft and crankshaft are not in time or a faulty cam/crank sensor
  • Posted 15 Nov 2024 08:18
  • By andrew_k
  • joined 17 Mar'07 - 338 messages
  • England, United Kingdom
Can you clarify what that would be telling me?
  • Posted 15 Nov 2024 08:16
  • By tg0486
DTC 190-8- Crank/CAM Synchronization
  • Posted 15 Nov 2024 08:01
  • By andrew_k
After entering the password, it shows the last fault as ECU 190-8 #4 if that helps anyone. I plan to have one of my guys check the fluids tonight.
  • Posted 15 Nov 2024 02:28
  • By tg0486
TGO,
If you are not seeing a code come across the screen on the dash, suspect the wrench light is on due to low fluids. You can bring up any stored codes to come up on the screen by entering the password saved in the lift. Press the asterick key until you see enter password on the screen. Enter all 5's and hope it has not been changed from the factory. Enter 5 5's then press the pound key to enter the value. If it accepts the password, you will be able to navigate through the menu. If the password is not accepted, you will need the local dealer to check the codes with a program. Thanks.
  • Posted 13 Nov 2024 23:25
  • By Fishmech
Service light??
  • Posted 13 Nov 2024 09:48
  • By andrew_k
TGO,
From what you are saying, no codes are showing on the display. Need to check all fluid levels. This would include coolant, engine oil, transmission oil, brake fluid and hydraulic oil. Make sure you add the correct fluid for each system. Operator manual should have a list. If light remains on need to call your local dealer. Good Luck.
  • Posted 13 Nov 2024 07:12
  • By Fishmech
SMV (Konecranes) 33-1200C
Manitou MH25-4
Sue Tomic Sue Tomic
Manitou MH25-4
Noblelift
