Piston on rod cgc25
Not sure if this ok.Piston rocks on rods and also spins with some slight resistance. Also some scuffing of grooves on top edge of piston. Cylinder bore looks ok. No wear on seals.
  • Posted 8 Oct 2024 12:05
  • By John_Phillips
  • joined 6 Oct'24 - 12 messages
  • Washington, United States
John phillips
I can't figure out how to remove it.
  • Posted 8 Oct 2024 13:53
  • By John_Phillips
John phillips
Remove the piston from rod and check the
Stub shaft it rides on I believe there is an o ring on it that seals the stub shaft it could be bad
  • Posted 8 Oct 2024 13:47
  • By John_Bradley
  • joined 10 Aug'22 - 271 messages
Jb69
