power steering problem
Hello. need help on a e60z33. power steering works good and sometimes not working when it happens i need to turn key off after turn on it works great i checked power to power steering motor and no power the contactor has power but nothing to motor. if i turn ing switch off on motor starts to work. can someone help pls. thanks
  • Posted 22 Aug 2024 13:03
  • By hyster_clark
  • joined 22 Aug'24 - 3 messages
  • Quebec, Canada
I just did one problem is the senser
  • Posted 12 Sep 2024 04:35
  • By hyster_clark
  • Quebec, Canada
Hyster,
The steer sensor in the steer column may have failed. Remove steer column cover, turn lift on and move steer wheel. Look for led light to come on at sensor. If the light goes off at any point, replace sensor. Should the light not come on, unplug the connector and check for battery voltage across 11D and 13X. If you have battery voltage replace sensor. Also check fuses 4 and 7. The steer motor cannot be rebuilt. The controller and motor are one assembly. Good Luck
  • Posted 12 Sep 2024 01:57
  • By Fishmech
  • Virginia, United States
The contacts are new and power in and out works great but the wires to motor have power sometimes not power to steering motor I check out contacts they are working. Thanks for your reply
  • Posted 24 Aug 2024 10:48
  • By hyster_clark
  • Quebec, Canada
Check the contact tips for wear and see if they are burnt the tips can get residue on them and lose contact across them
  • Posted 24 Aug 2024 08:56
  • Modified 24 Aug 2024 08:59 by poster
  • By John_Bradley
  • joined 10 Aug'22 - 253 messages
Jb69
SMV (Konecranes) 4632TC5
Mitsubishi FGE35AT
