SLOW MODE
Good afternoon, I introduce myself, I am Nicolas and I am grateful to be part of this group. You do a good job and I am willing to help with whatever knowledge I have. Now I have a problem with a forklift that only goes slow. It is an EFG 220 from 2015. The steering and accelerator pedal have been learned, it does not show any faults, but the machine only works in slow mode. If anyone can help me I would greatly appreciate it.
  • Posted 3 Jul 2024 03:40
  • By NICOGRAO
  • joined 3 Jul'24 - 8 messages
  • Spain
Nico
Hello, I can't find it in any option.
  • Posted 5 Jul 2024 23:32
  • By NICOGRAO
  • Spain
Nico
Have you tried reseting hydraulic functions? There should be a reset avaliable that only resets hydraulics.
  • Posted 5 Jul 2024 22:34
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
Hello. Thanks for your answer. By displacer I mean the lateral movement of the tips. Everything works correctly, elevation, tilt and movement. The truck was reset for unknown reasons. I suspect that the function is not activated and I cannot find a way to activate it. Before the reset everything worked correctly, but some mechanic without knowledge had to reset the machine. Thank you.
  • Posted 4 Jul 2024 23:56
  • By NICOGRAO
  • Spain
Nico
I have no idea what you mean by scroller, but I suspect you describe one of the hydraulic functions. In this case if the judit shows signal on solo/multipilot, but the valve doesnt open, it's either not programmed as a function, or conditions are not met for this function to work(mast height/freelift sensor) also may he a broken wire for coil supply, but that's rare. Check h1,h2,h3,h4,h5 function assignments in judit, check wires, make sure all safety functions work.
  • Posted 4 Jul 2024 17:09
  • By Tanel_M
  • Estonia
Hello, thank you very much for your response, I was able to resolve it, I had to enter with Judit as a forklift from 2016 onwards and there was an option to detect mast elevation. This truck does not have that sensor. I have disabled it and it runs now. The truck reset itself involuntarily. Now the problem I have is that the scroller does not work. I measure the voltage of the solenoid valves and there is no current but the trigger does give a signal in Judit. It still doesn't give any errors and I don't know how to activate the displacer.
  • Posted 3 Jul 2024 21:28
  • By NICOGRAO
  • Spain
Nico
Slow mode as in screen has turtle? Or slow as in you press the pedal and it drives slow? One of the common mistakses is, that after maintenance the floor mat is too near to accelerator pedal, thus reducing the maximum speed, as the accelerator fails to reach maximum value.
  • Posted 3 Jul 2024 20:59
  • By Tanel_M
  • Estonia
