Error code 3.547
Bt stacker with fault code 3.547.
Nothing runs, main contactor doesnt close at upstart.
The fault description says its something drawing too much power/short circuit in the output:
"High end driver" in T1.
What does this mean?
Thankful for any help given!
  • Posted 8 May 2024 03:15
  • By MrForklift
  • joined 23 Oct'21 - 16 messages
  • Sweden
Check your (relais)coils and brake with ohm meter.
  • Posted 6 Apr 2025 06:17
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
Ik heb hier hetzelfde probleem.
Is er al iets bij je bekend.?
Please use English language
Littoral Translation
I have the same problem here.
Is there anything known to you.?
  • Posted 5 Apr 2025 20:12
  • Modified 8 Apr 2025 05:12 by poster
  • By Toyota
  • joined 5 Apr'25 - 1 message
  • Netherlands
