car jumper cables to see hour meter
Can i use car jumper cables just to see the hour meter on 2014 Crown-wave 50-118
if so how can i do it?
  • Posted 23 Apr 2024 19:11
  • Modified 23 Apr 2024 21:09 by poster
  • By arham_b
  • joined 18 Dec'18 - 5 messages
if it a'int onlne it does not exist
If you are able to Lift and lower, that means the lift passes its self check. It could be a few things, but without me being there it is hard to say.
My recommendation is to test the drive circuit to see if the controller is even sending voltage to the motors or where there is an issue.
  • Posted 10 Jun 2024 09:16
  • By DyslexicNerd_01
  • Wisconsin, United States
Thanks, well i ended up buying 4 new batteries ,so everything works fine ,the boom goes up and down from the base panel,but it wont move back or forward
standing on two round foot posts ,locking the door, what am i doing wrong? never used any forklift or such machinery before.
  • Posted 9 Jun 2024 23:09
  • By arham_b
Are you charging it using the Edison plug on the service panel? If so there should be a steady yellow light with a blinking green light to show it is charging. This can charge the lift using general outlets. If it is not showing any lights it is not charging. There needs to be atleast 22v over all 4 batteries for charging to start.
  • Posted 3 May 2024 05:51
trying to charge it with a 2000 watt generator, should it show charging light right away, because its not showing yet any lights
  • Posted 3 May 2024 04:55
  • By arham_b
Thanks a lot sir ,ur timely advice is highly appreciated.
  • Posted 24 Apr 2024 08:23
  • By arham_b
You would have to open the bottom cover to expose the batteries and find a postive and negative cable that are over 2 batteries creating 12v (if your charger is 12v). If the lift is completely dead to where you need to jump it to even get the hour meter to show, it sounds like you have bigger problems and might want to charge the lift before it causes major damage to the batteries.
  • Posted 23 Apr 2024 21:48
VETTER Industrie GmbH
Aichi RX07B
Maxlion FDR45
