Event Code 176
Hi, I have a Crown SC5200 unit that originally had error code 305, we changed Access 3 and now shows code 176. The manual does not have any code or any bulletin. Any help will be greatly appreciated it.
Thank you. Carolina
  • Posted 18 Apr 2024 04:45
  • By UPC8532
  • joined 11 Nov'16 - 8 messages
Hi. Have same code. Did you figure out at end?
  • Posted 13 Feb 2025 08:03
  • By Yidneck
  • joined 20 Jan'17 - 110 messages
Dreamt I was fixing a machine, then came the paperwork and it turned into a nightmare.
First I would go into the service menu on the original access 1 module and go into features 20.1 and turn off the battery restraint feature. It could be this lift does not have a battery retainer switch and updating the software caused it to be reenabled.
  • Posted 18 Apr 2024 05:03
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 223 messages
  • Wisconsin, United States
Hi, correct. We replaced the access 3 due to code 305 and new software was installed to the whole truck. After doing this code 176 shows up as well as the wrench. We tried switching module 1 from the SC to a FC but the screen is black. Maybe module 1 is bad? Thanks.
  • Posted 18 Apr 2024 04:57
  • By UPC8532
When you installed the new access 3 did you flash software to the whole truck? New modules do not come with software pre-loaded. All the modules also need to have the same software version so even if the new module came with software it might be the wrong one. Typically if a crown throws a code that does not exist it means one of the modules isnt configured correctly. Seems like you replaced the access 3 due to code 305?
  • Posted 18 Apr 2024 04:52
UN Forklift FGL18T
Enforcer FD50T-MMA
Hawker Powersource, Inc.
Muncie, IN, United States
UN Forklift FGL18T
Enforcer FD50T-MMA
Deborah Baker Deborah Baker
