Password
Just replaced a damaged proximity switch on rear steer wheel. Need password to clear fault code.
  • Posted 19 Mar 2024 23:41
  • By Pat_Simkins
  • joined 3 Apr'20 - 10 messages
  • New Jersey, United States
Pat Simkins
Whats the fault code and engine in the unit? To my knowledge no codes will be thrown for a damaged prox switch and may be an engine dtc.
  • Posted 20 Mar 2024 13:39
  • By BLey
  • joined 31 Jul'20 - 60 messages
Hi Pat,
If you still need support, you can complete a quick technical support form at the bottom of the main combilift.com web site or direct link https://warranty.combilift.net/technical-support-form/. The form only asks for the minimal info so the team can quickly help you. There is no login required and no charge for this support.
Combilift has Technical support technicians based in Combilift North America Headquarters, in Greenboro, NC, will respond.
You can also request access to the Knowledgebase where you will find more information available. Hope you get sorted.
  • Posted 20 Mar 2024 00:52
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
