Error 62 and 99
Hello,
I have a problem. It gives me error 62 and 99 PIMESPO ??20 electric car. From the description I have of the errors it tells me to go into the display settings and reset the errors from there. Does anyone know how to get into the display settings so I can do a bug reset?
Thanks
  • Posted 15 Mar 2024 02:18
  • By Lyudmil_Petkov
  • joined 12 Mar'24 - 6 messages
  • Bulgaria
error 33
Wrong serial number for that Andrew i think....This is the older "early" XE model and not what OM would consider the "AC truck".
Lyudmil,
Error Code 62 relates to "The currents stored in the POWER Module are not the
same as those stored in the DISPLAY Module. Traction is disabled, but braking remains enabled. Reset the alarm by activating the AUX CURRENT #1 option on the DISPLAY Module".
So you'll either need OM Laptop Software or a Hand Held Consul to enter relevant programming, you can't do it without one or the other i'm afraid, and adjust the Display Modlue settings. However unless this error message has always been present to the truck or unless a module has been swapped it's highly unlikely the truck has changed it itself so shouldn't need re-setting....
Often find many Current related codes appear as part of a wiring fault. The usual suspect is the left and right motor Field control wiring where it enters the control panel via 2 x two pin multiplugs and one for each motor FDX and FSX (1 red and 1 black wire from memory). Check the multiplugs for signs of burning or poor connection. I can send details via e-mail if required - address in my profile.
Yes Code 99 relates to service overdue to hours set between intervals as Andrew says.
E-mail me if required....
Dez
  • Posted 5 Apr 2024 08:23
  • By Dez_A
  • joined 3 Jun'04 - 84 messages
  • Middlesex, United Kingdom
Service life of a forklift is proportional to how well it is maintained.
Code 62
Encoder error
One of the 2 encoders (or both) does not detect the
voltages/currents applied. If speed control is enabled,
the speed is reduced when moving
Code 99 could possibly be service overdue
  • Posted 5 Apr 2024 05:45
  • Modified 5 Apr 2024 05:49 by poster
  • By andrew_k
  • joined 17 Mar'07 - 334 messages
  • England, United Kingdom
The number is 14017P00436 , Fabrication 2003 year. XE20 model.
  • Posted 5 Apr 2024 05:09
  • Modified 5 Apr 2024 05:10 by poster
  • By Lyudmil_Petkov
  • Bulgaria
error 33
Hi Lyudmil - What is the truck serial number (4032)?
  • Posted 4 Apr 2024 19:13
  • By Dez_A
Komatsu FD25T17
SMV (Konecranes) 16-1200C
