Strange sensor found on chassis gives error E0608
Does anyone know what this is? It's a sensor with catalogue number 51064284, mounted on the chassis between traction and hydraulic motor.
I can't find anywhere what it's used for , but the machine has error E0608 index 0024 and drives slowly...The customer has two of the same trucks, and when we disconnect this sensor the other truck has the same error, so we tried pulling it from the chassis to try to interchange it ,and it broke because it's glued to the chassis, so i presume it's a tilt sensor??
I can't find new one nowhere...Is there a workaround of that sensor?
  • Posted 17 Nov 2023 01:51
  • By HUZO
  • joined 27 Mar'17 - 28 messages
  • HR, Croatia
those who believe in telekinetics,raise my hand!
sounds to me like an impact sensor or something of that sort.
i'd have to see it to be sure though.
  • Posted 24 Nov 2023 14:15
contact me in private
  • Posted 21 Nov 2023 04:16
  • By imad_b
  • joined 8 Dec'17 - 47 messages
  • oulfa, Morocco
imadi.bakhat@gmail.com
+212663576104
crdt
Just order new from jungheinrich noting yoyr machine's serial number.
  • Posted 21 Nov 2023 04:07
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
Can you help with instructions?
  • Posted 21 Nov 2023 01:40
  • By HUZO
  • HR, Croatia
So we have a problem now?It is broken and i found two small transistor like components marked DS2431...They are some sort of 1024-Bit 1-Wire EEPROM...
What to do now...there is no way of repairing it or bypassing?
  • By HUZO
  • HR, Croatia
This is a coding chip in the chassis, it's not replaceable and it holds the truck details, it cross references the data with the safety controller
  • Posted 19 Nov 2023 18:59
  • By Rick_86
  • joined 19 Nov'23 - 1 message
  • England, United Kingdom
how? explain, we have the judit 4 software....
  • Posted 17 Nov 2023 06:46
  • By HUZO
  • HR, Croatia
hhh you must upgrade the service parameters it s simple
  • Posted 17 Nov 2023 06:35
  • By imad_b
  • oulfa, Morocco
+212663576104
crdt
