Engine codes 09-2 09-3 no fire on Cylinders 1 and 2
no fire on cylinders 1 and 2, 4 coil system. has engine codes 09-2 and 09-3, not in service manual, good power and ground to #1 and 2 cylinder coils.
  • Posted 30 Jun 2023 04:23
  • By Adam_Hoggatt
  • joined 30 Jun'23 - 1 message
Adam Hoggatt
Can you send me wiring diagram manual for this model engine?
I have all of wiring diagram for Toyota engine and series.but this model I don't have.
My phone number is +989395094590.
I have telegram and WhatsApp messenger.
Thank you
  • Posted 30 Apr 2025 03:10
  • By Afshin
  • joined 29 Aug'23 - 34 messages
  • Iran, Islamic Republic Of
I found problem.
Some resistor and zenner diode in ecu was burned.
I replace resistor and Diode,fult code is gone , every thing is ok.
Thank you very much for your helping
  • Posted 30 Apr 2025 03:07
  • By Afshin
Remove the coils and ohm out the pins. Coil defect, igniter defect, harness defect, ecu defect. Did you run the plugs to long? Disconnect you replace plugs? With the right plugs? Coils take a different number than regular 4y plugs. 1500 hrs max or it will burn out coils. Disconnect the negative battery for 15 seconds. Check all connections in harness to coils. Check all fuses removed. Have to check continuity from G-28 to G130,141,132,133. #2 pin to G28. Pins 18,19,28,29. If harness is good then ecu issue. Battery positive is from fuse. Neg is from ground to frame. Igt1,2,3,4 is from ecu. These are the pin checks.
Verify connections and hook up negative. Start. If code is there then it's an ecu issue.
  • Posted 29 Apr 2025 03:15
  • By ron_k
  • joined 2 Apr'15 - 124 messages
  • North Dakota, United States
4kliftman
Hi dear friend.
Im repairing Toyota forklift 8FG25 with error code E09-3.
Do you solve it?
  • Posted 22 Apr 2025 03:28
  • By Afshin
Komatsu FD25T17
UN Forklift FGL35T
Bolzoni SpA (Group HQ)
Komatsu FD25T17
UN Forklift FGL35T
