hydraulic pump
Forklift details
MAKE: LINDE
MODEL: E16C-03
SERIAL NUMBER: C1X335E04263 /2014
Capacity: 1.6T
ERROR DETAILS
1. L225
2. L863 - (Doubt - LIFT CONTROLLER ERROR )
3. L286
PROBLEM & action taken
1. After running for a few minutes hydraulic functions stop with error L225 or L863 together.
2. We identified pump metal particles and dust in hydraulic oil. We replaced all hydraulic
filters, air filter and Hydraulic oil.
3. Pump suction side damage (Cavitation). we replaced the pump but still noise while lifting
( like less suction or suction leak)
4. Valve block cleaned
5. Hydraulic AC Motor winding and frame leak checked seems ok
Any help on above will be appreciated.
  • Posted 15 Jun 2023 20:47
  • By Isa_Alderazi
  • joined 25 Feb'21 - 10 messages
  • Bahrain
Isa Alderazi
Las partículas de metal han podido ser producidas por un motor hidráulico, no sé cuantos lleva ese equipo.
Si hay algún otro elemento hidráulico que ha podido producir esas partículas, sería conveniente revisarlo internamente.
Puedes volver a tener partículas en el circuito, aún con los elementos nuevos.
  • Posted 23 Jun 2023 15:31
  • By Koldo_Martinez
  • joined 11 Mar'23 - 15 messages
  • Spain
Thanks all!
Thank you dear for the support, Yes we checked the cap it is fine nothing wrong with it.
  • Posted 22 Jun 2023 17:40
  • By Isa_Alderazi
  • Bahrain
Isa Alderazi
hello, did you replace the hydraulic tank cap? it may be cracked if the circuit has not been depressurized properly.
  • Posted 22 Jun 2023 06:03
  • By FrenchTech
  • joined 15 Mar'22 - 11 messages
  • France
French Technician
Still Linde Fenwick Jungheinrich
Bolzoni SpA (Group HQ)
