Event code 168
Can anyone explain to me the fault I'm getting that states EPS EWS Err =168...I'm at a loss as to where to begin.
  • Posted 6 May 2023 00:59
  • By Poppi
  • joined 6 May'23 - 1 message
  • Virginia, United States
I am having same code, my forklift has a led acid battery, did you happen to find a solution?
  • Posted 28 Feb 2025 18:35
  • By Shamo1986
  • joined 28 Feb'25 - 1 message
  • Baja California, Mexico
What if you are getting 168 accompanied with 105. But break coils are good on voltage and checking them under analyzer. We also have hydrogen fuel cell.
  • Posted 1 Aug 2023 13:07
  • By BStrick
  • joined 1 Aug'23 - 1 message
  • Alabama, United States
You have the lithium-ion battery
It says view the external display, turn the battery on, if you get a fault from the led flashing then troubleshoot that battery code.
Check battery state of charge, confirm the EPS harness is correctly connected
Basically it's saying a battery or connector problem.
  • Posted 7 May 2023 23:26
  • By Zerk
  • joined 21 Apr'16 - 28 messages
  • Arkansas, United States
Toyota 8FD45
Hangcha FLDCXT160
Sue Tomic Sue Tomic
Hyster
