hydraulic lift motor kicks on hi everytime I hit the throttle.
Hello I need help! I been working on this lift for several weeks. I sent the controller to get fix and when it came back started giving me this problem. When I'm pressing the accelerator pedal the hydraulic pump goes on high and doesn't stop until a release the pedal. I took the controller off and send it again for warranty work but they told me that everything checks good. Had anyone encountered this problem before? Lift info J60XN-34 serial# A276B01849H
  • Posted 29 Apr 2023 05:40
  • By edgar_p
  • joined 9 Oct'12 - 3 messages
  • Arizona, United States
Edgar P
Edgar,
Since having the controller repaired have you checked all settings? Could be a setup feature that needs to be adjusted. I do not have the settings in front of me, but see what I can find. Good Luck
  • Posted 5 May 2023 09:30
  • By garland_m
  • joined 16 Oct'09 - 213 messages
  • Virginia, United States
Work Hard and Fish Long
