Seems as if the brakes are on in reverse.
I have a GLP050 it goes forward fine, but if I put it in reverse it seems as if the brakes are on and it won't go. Is this a brake issue?
  • Posted 5 Nov 2022 04:03
  • By Hangover
  • joined 6 Sep'19 - 25 messages
  • Arizona, United States
most likely yes, jack up the front and spin the wheels. They should have a slight drag but turn in both directions. If they are hard to turn or don't move then the shoes are too tight and you will need to de-adjust them.
You'll need a brake spoon and go in through the access holes in the bottom of the backing plate, there should be rubber plugs in the holes (if the last tech that worked on them didn't throw them away). They should be in there to keep outside dirt and water out.
You can also use some compressed air and blow in through the back inbetween the hub and backing plate, that should get most of the brake dust out. Make sure you wear a respirator or have a mask on to keep from breathing the dust that comes out.
  • Posted 8 Nov 2022 00:15
UN Forklift FGL18T
Toyota 8FG25
Jim Tompkins Jim Tompkins
Sales operations, Heli
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
