3516-11 code
Recently acquired an H155FT Kubota diesel. Get fault 3516-11 and lose throttle control. Only info I can find on this code comes back to a CAT and has to do with def quality. Can't find this fault code under hyster. Hoping someone here can point me in the right direction. Thanks.
  • Posted 3 Nov 2022 06:03
  • By Zan_Thompson
  • joined 3 Nov'22 - 2 messages
  • Oklahoma, United States
ZRThompson
Zan,
These sensors are known to fail. Make sure you test power between the red and black wire at the connector, battery voltage. Using the black wire as negative, check the green and yellow wire for about 2 to 2.5 volts. If voltage checks are good, replace sensor. Good Luck
  • Posted 5 Nov 2022 23:16
  • By garland_m
  • joined 16 Oct'09 - 212 messages
  • Virginia, United States
Work Hard and Fish Long
Thanks. Yep. We're dropping the tank to get to the sensor. Going to try cleaning it.
  • Posted 4 Nov 2022 12:17
  • Modified 4 Nov 2022 12:17 by poster
  • By Zan_Thompson
ZRThompson
DEF quality sensor error check the power and negative to the def tank header and the canbus also there is 10a fuse for the voltage input
  • Posted 4 Nov 2022 01:43
  • By Forlift2001
  • joined 22 Apr'14 - 5 messages
Ncn 110TH
Ncn 110TH 2015
Factory Cat MICROMAG20D
Deborah Baker Deborah Baker
