Dash doesnt light up AND no start??
I told my buddy I would have a look at his forklift. Not sure the year but seems "newer". The complaint was NO START. First thing I noticed was the dash screen or any lights do not light up at all. I thought Id start by looking at the diagnostic codes......but the screen doesnt light up. The forklift cranks but will not start.
So before I went in too deep......Is there a relation here? Should it matter if the screen doesnt light up? Or is this telling me the ecu/computer is dead or?? fuse or??
K25L Nissan engine. Unsure of year?
Thanks for the help!!
  • Posted 16 Oct 2022 04:22
  • By Jinxie
  • joined 27 Jan'18 - 19 messages
  • Manitoba, Canada
Hello,
Please advise if you found the solution and what was the issue. I have exactly the same issue. I appreciate your advise a lot!
  • Posted 17 Mar 2025 12:01
  • By Region64
  • joined 17 Mar'25 - 1 message
Vladimir
I know this thread is old but I have the exact same problem. Did you find the cause?
  • Posted 16 May 2024 11:22
  • By Topi
  • joined 16 May'24 - 2 messages
  • Oklahoma, United States
Jonathan
I'm having the same problem with my forklift, what did you find out?
  • Posted 15 Oct 2023 10:45
  • By Jason_Hazelwood
  • joined 15 Oct'23 - 1 message
  • Virginia, United States
Jason Hazelwood
Found it!
  • Posted 16 Oct 2022 05:55
  • By Jinxie
  • Manitoba, Canada
Ok so I pulled the plug from the bottom of the fuse block there were only 2 wires there in the plug. But when I jumped 2 out of the 3 pins at the bottom of the fuse block the dash lit up! And it starts!!
So, does anyone know where I can get a schematic? Im close....just need to understand what I jumpered and where the other ends of these 2 wires go,
Must be an ignition relay somewhere?
  • Posted 16 Oct 2022 05:06
  • By Jinxie
  • Manitoba, Canada
I tested for power in the fuse block
NO POWER at these fuses (These 6 are beside each other)
VCM
QGS/OTHERS
METER PANEL
BACKUP/OTHERS
These fuses HAVE POWER
WORKINGLAMP
ETC
A/C
WIPER
HEADLAMP
HORN
STOMPLAMP
EGI
EGI
So.....Where does my power for the first fuses come from? Relay?
  • Posted 16 Oct 2022 04:51
  • By Jinxie
  • Manitoba, Canada
Taylor XC300M
New - Sale & Hire
UN Forklift FD25T-C2JM1
