PREHEATING/MALFUNCTION ON DISPLAY
Hi!
I'm new here and had already posted several questions. Hope you'll still help me :(
Anyways, our linde unit had a PREHEATING/MALFUNCTION displayed on screen and icon also lits up when running for a long time. Normally, the preheating icon lits up during startup but this time it is different. May I ask if you had encountered this error?
  • Posted 8 Oct 2022 14:45
  • By Jayson
  • joined 21 Feb'22 - 12 messages
  • Philippines
It sounds as though the unit has an issue with
Emissions you need to have pathfinder to retrieve the codes but you may check the
Vacuum lines to the small valves located on right side of engine compartment next to radiator other than that you will need pathfinder
  • Posted 8 Nov 2022 17:32
  • By John_Bradley
  • joined 10 Aug'22 - 271 messages
Jb69
probably there is a wire or sensor that reports an error when it gets hot
  • Posted 9 Oct 2022 00:59
  • By michel_v
  • noord holland, Netherlands
But the unit is still running for now. The error only comes out when the unit is used for a long time. To reset, we turn off/on the unit and it will be working again.
  • Posted 8 Oct 2022 18:49
  • By Jayson
  • Philippines
you have an engine failure
  • Posted 8 Oct 2022 18:17
  • By michel_v
