No drive. No steering. Numerous fault codes.
Hi all.
Toyota 8FBE20T (S/N 10439) Built in 2016. 48V
Fault codes on immediate start up: 0251 & 0351
Couple of seconds (& clicks) later, these codes appear also: 04F5, 01ED & 413C.
Connected the truck to a different battery - no difference to behaviour.
Hydraulics work without issue.
Steering is electrically operated on this forklift.
Any ideas on where to begin?
Many thanks,
Damien.
  • Posted 20 Sep 2022 03:18
  • By TheDamo
  • joined 23 Feb'18 - 11 messages
  • Offaly, Ireland
Best regards,
Damien.
Bonjour,
J'ai le problème sur un charriot TOYOTA électrique modèle 8FBE18T-13251
L'avancement ne fonctionne plus j'ai les codes suivant 04F5 0251 0351 01ED 4148
De votre coté comment avez vous résolu le problème?
Merci d'avance
Please use English language
Littoral Translation
I'm having this problem with a TOYOTA electric forklift model 8FBE18T-13251.
The forward motion is no longer working. I have the following codes: 04F5 0251 0351 01ED 4148.
How did you resolve the problem?
Thanks in advance.
  • Posted 7 Jun 2025 02:56
  • By REMI_DEWAELE
  • joined 7 Jun'25 - 2 messages
  • France
Comment avez vous résolu votre problème?
Merci
Bonjour,
J'ai le même un problème sur un charriot TOYOTA électrique modèle 8FBE18T-13251
Comment avez vous résolu le problème?
Merci d'avance
  • Posted 7 Jun 2025 02:53
  • By REMI_DEWAELE
  • France
Merci
Hi tr_doctor!
how can i get the new generation dashboard fault codes for the same toyota model?
An inoperative 8FBE20T produces many error codes and I don't understand their meaning
0253, 0147, 0148, 0149, 05A5, 0219, 04FE, 413C, 01ED, 0351, 04F5
Thank you in advance
  • Posted 27 Jul 2023 18:10
  • By Csaba_Vagasi
  • joined 27 Jul'23 - 1 message
  • Hungary
Some testing of the forklift done over the weekend.
Results all seemed to point to issue with steering controller.
Controller gone for further testing, but I'm pretty confident that it's kaput.
Thanks for the guidance tr_doctor. Much appreciated.
  • Posted 27 Sep 2022 02:37
  • By TheDamo
  • Offaly, Ireland
Best regards,
Damien.
Hello ,
Check small contactor in counterweight for EPS steering. If good and not coming in you have trouble inside the steering unit. You must replace for new.
  • Posted 27 Sep 2022 01:49
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Sue Tomic Sue Tomic
