Code 27
Code 27 is battery low but is completely charge up but when going in either forward or reverse it codes 27, need help with code
  • Posted 7 Jun 2022 13:18
  • By Hoist
  • joined 17 Apr'22 - 4 messages
Next thing you can do is tune-up the oscillator card, you need the service terminal to do that and the crown service manual.
  • Posted 9 Jun 2022 16:20
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
Thanks, water level is good and battery fully charge, also test truck with another good battery and still gives code 27. Also I replace the transistor, could I have a bad transistor can it cause code 27, I never seen this, any advise
  • Posted 8 Jun 2022 19:57
  • By Hoist
I suggest that you connect your meter leads to the battery cables and watch the voltage as you drive either direction.
More than a 20% decrease in voltage when a motor is energized indicates a seriously depleted battery.
I'll also suggest that you take a look at the water levels for each cell.
Lots of people ignore battery maintenance.
  • Posted 8 Jun 2022 09:09
  • By LaGrange
