Carriage drifts up when reach is extended or retracted
The MTC handle has been recalibrated with no effect. Fluid level is good. No debris in the filter. Pulled valves from the main manifold but found nothing obviously wrong. Had suspicions about SCby so it was swapped out but no improvement. PCA, PCL and PVA were changed out as well with the same results. There's no external signs of cracking of the manifold but could it be leaking internally?
  • Posted 16 Mar 2022 10:56
  • By Michael_Webb
  • joined 24 Jun'20 - 24 messages
Replace handle base, that's most likely the culprit.
  • Posted 22 Jun 2022 15:32
  • By Ratm
  • joined 21 Jun'19 - 17 messages
Stoney
try checking for broken or shorted wires in mast and reach assembly. Have seen that happen before on RD5200
  • Posted 16 Mar 2022 23:26
  • By JMC1
  • joined 8 Nov'18 - 50 messages
  • Iowa, United States
Sue Tomic Sue Tomic
