fc4525-50 no forward/reverse, steering or hydraulics
Hopefully someone can help with this issue i have been trying to figure out.
the lift will key up and the dash display works as well as the lights and horn.
the p/s will not come on when on the seat.(seat switch is good), the hydraulics do not work and no f/r travel. one contactor pulls in on key up. All stored codes are the same (331) battery is good as well. Any help is appreciated. Thanks
  • Posted 20 Feb 2022 10:10
  • By pops
  • joined 20 Feb'22 - 2 messages
pops
One thing to check because it's easy. There is a safety interlock switch that needs the battery side covers to be on for the truck to operate. Make sure that switch is closed. Located at the bottom where the cover slides in.
Is code 331 a current code? If it comes up every time you try to run then it could be the problem although usually traction codes don't affect hydraulics. If it's from a month back and not coming up every time then it's probably not the main problem.
I've had trouble with the distribution board on some of these trucks. It's located under the step for getting on the truck. You might want to check all connections and tap on the relays, check fuses etc.
I can't find a code 331. Sometimes they're not in the book though. I'd check the sensor wiring at the sensor and at the Access 3 panel. The red wire at the sensor is +12 V and goes through wire 312 to pin 1 on the panel. The black wire is battery negative and goes through wire 517 to pin 2 on the panel. The blue wire is Chanel B and goes through wire 015 to pin 14 on the panel. The white wire is Chanel A and goes through wire 014 to pin 13 on the panel.
Chanel A and B produce square waves that go up in frequency as the motor speed increases. The square wave would be measured between blue and black for channel B and between white and black for channel A.
It might be quickest to swap Access 3 panels if you have a sister truck. See if the problem follows the panel.
And I don't have to tell you to have the drive wheels off the ground right? If the forklift runs you over then they have to find someone else to fix the truck.
Likewise there's safety concerns when removing and installing the battery.
  • Posted 13 Mar 2022 05:36
  • Modified 13 Mar 2022 05:50 by poster
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
Lumberjack,
Yes the line contactor pulls in but not the steering contactor. I was told the code 331 is the drive motor sensor. if it does not recieve a signal back it will not turn on. not sure on that.
Thanks
  • Posted 13 Mar 2022 03:43
  • By pops
pops
Does it have a line contactor, and is it pulling in? Crown may call it a main power contactor. But the idea is the same, lift and travel don't get power until it pulls in. It works from the key switch and probably the seat switch.
  • Posted 25 Feb 2022 05:38
  • By lumberjack
Terberg YT223
UN Forklift FD35T
Lift Technologies Inc.
Terberg YT223
UN Forklift FD35T
Brothers Adolf ("Adi") and Rudolf ("Rudi") Dassler split their shoe company after WWII due to a bitter feud, and established the rival companies of Adidas and Puma. Their personal animosity and business rivalry divided their German hometown Herzogenaurach. The town became known as "the town of bent necks" due to the intense loyalty to each brand.
