No Hydraulic function
Hi all, got a Mitsubishi FD25 EF18B year 1996 with no hydraulic functions. I've bypassed the seat switch and isolator, I checked wiring and plugs to find ok, removed the control box at the side of battery and checked the red led status to find no light. I managed to source and fit a spare box and everything worked fine for a short while and it's now done the same! I have no knowledge or information on this so could really do with some help. Not sure if it's something blowing the box or something that just may need resetting?
Regards Pete
  • Posted 30 Jan 2022 03:25
  • By Biglifter
  • joined 26 Jan'21 - 8 messages
  • United Kingdom
that can't be a n series it must be a k
  • Posted 2 Feb 2022 03:19
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
Hi mate this is an earlier model 1996 as it doesn't give error codes on the dash just the red warning triangle. The controller is mounted under the bonnet behind the battery. As mentioned we fitted a spare controller and it was fine for an hour then it did the same, no hydraulics. Is there a procedure to reset the controller?
  • Posted 31 Jan 2022 18:43
  • By Biglifter
  • United Kingdom
If its driving no problem with seat sensor check unlock solenoid would of thought you'd have a code up will probably need to plug in and use truck tool to see what's going on the controller is pretty bombproof check plugs going into controller they can corrode being under the step
  • Posted 31 Jan 2022 18:02
  • By alanmitsi
Hello mate thanks for your reply.
It has the fingertip controls.
Regards Pete
  • Posted 31 Jan 2022 03:44
  • By Biglifter
  • United Kingdom
Is it fingertip or lever control
  • Posted 31 Jan 2022 03:10
  • By alanmitsi
Libiao Robotics
