e15n om pimespo
la tensión de VMN es mayor que los 2/3 VBATI, controlador muevo, puede ser que hay que configurar la tension del controlador?
Gracias.
VMN voltage is greater than 2/3 VBATI, I move controller, could it be that we have to configure the controller voltage?
Thank you.
  • Posted 8 Jan 2022 00:45
  • By juanlao
  • joined 22 Jun'18 - 27 messages
  • islas baleares, Spain
Repair, not replace.
ok, repasado el colector del motor esta bien, y tengo una tension de 49,7v. la unidad de control de traccion es reconstruida, y tiene un diodo de protecion cruzado, me da continuidad entre el positivo y vmn.
Gracias por tu comentario tr_doctor
ok, reviewed the engine collector is fine, and I have a voltage of 49.7v. the traction control unit is rebuilt, and it has a crossed protection diode, it gives me continuity between the positive and vmn.
Thank you for your comment tr_doctor
  • Posted 12 Jan 2022 22:36
  • By juanlao
hello , check first with vmn error the motor are oke. If collector of motor or brushes not clean give this error.
  • Posted 11 Jan 2022 19:48
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Kai von Berg Kai von Berg
Lift Technologies Inc.
