wont switch forward to reverse without cycling key
just wondering if someone has run across this problem
our old Yale not sure of year 1989ish
ERP040BBN36SE033EE:
N492816
older ev panel no handset plug on card
new battery and forward/reverse switches exact same problem
place in forward will drive all day no problem
shift to reverse nothing no forward or reverse moving or not
cycle key on/off
select reverse drive all day no problem
shift to forward nothing no forward or reverse moving or not
cycle key
select forward or reverse and works but just wont switch when powered up with out even moving if you select forward then shift to reverse nothing
have to cycle key
anyone can gimme a hand id much appreciate it
3 repair companies have been into look at it including dealer money spent but none of them know for sure just want to swap parts
thanks guys
happy holidays
  • Posted 12 Dec 2021 02:34
  • Modified 12 Dec 2021 02:36 by poster
  • By Autodog
  • joined 27 Sep'12 - 12 messages
Current Sensor might be the problem.
You can also perform a Tune-up for the EV-1 Oscillator Card.
  • Posted 12 Mar 2022 13:13
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
from your description of the problem it sounds alot like the system is seeing a problem and generating a PMT fault causing it to reset making you cycle the key.
There could be a problem in the contactor tips bouncing when one or the other pulls in, it could be noise in the fwd/rev circuit that the PMT driver is picking up on, or from any of the other associated circuits like seat switch, accel switch, or even one of the components on the control panel failing the startup sequence.
These driver modules are small square blocks with 4 terminals sticking out of one side and most likely are stacked on top of each other inside the control panel area where the contactors are. You will need a manual schematic to identify which one is the PMTD module. The fwd and rev driver module is also in those square blocks along with the 1A driver.
If those tech's that looked at it weren't older guys with years of experience chances are they've never seen an EV1 panel (in person).
Those went away 25+ yrs ago.
So yeah, they might have a problem knowing how they work and how to check them correctly.
You can find info on the control panel on fsip's website
fsip dot biz and search in the 'Resources' tab and find technical documents and locate the GE Controllers and find the EV1 B C D link.
There is a troubleshooting chart in there but it is not mfg specific, it is only the control panel itself. Like i mentioned earlier, you will need a Yale manual for that truck model.
  • Posted 8 Mar 2022 11:38
sorry took so long i was off
yes its ev1 has flip door for adjusting
didn't realize i put ev100
  • Posted 8 Mar 2022 09:30
  • By Autodog
are you sure it's not an EV-1?
does it have a flip door on the front of the card to access the potentiometers for adjusting it?
All EV-100's have the plug for the handset from what i can recall.
  • Posted 12 Dec 2021 16:59
Michel Denis Michel Denis
