slow hyd
Need help speeding up the hydraulics on a Toyota 5FBE15, 29180 the customer just replaced motor and pump and unit is still lifting very slow we got called in to fix this and I cannot figure out how to speed up the pump speed any help would be greatly appreciated
  • Posted 21 Oct 2021 08:30
  • By Randy_Pierce
  • joined 11 Jun'21 - 3 messages
Randy P
On the left side of dashboard there are 4 pressure switches, select the fork indicator and then the up and down buttons.
  • Posted 8 Dec 2021 07:10
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
There's no speed up or down to change. The pump motor turns on full rpm when selected. Slow hydraulics is either oil filled with air bubbles or a bad pump. Need pressure taken to see what's changed. Also the pump splines to motor splines condition. Again if the pump is on and good battery, the slow hydraulic issue was present before the replacement.
Check also voltage configuration of pump motor. Most are 36/48v. Could be a odd one and wrong voltage.
Do you know if it has a pump chopper also ? Very few of these come out and blessed the market !
  • Posted 2 Dec 2021 23:23
  • By ron_k
  • joined 2 Apr'15 - 124 messages
  • North Dakota, United States
4kliftman
Muncie, IN, United States
Deborah Baker Deborah Baker
Toyota 8FG25
SMV (Konecranes) 16-1200C
RAEDER-VOGEL
