blinky code, 6,2
lift cuts out, and i get a 6,2 blinky code. Nothing on display. releasing the handle will reset, but it will promptly code again lifting. If I try lifting without putting handle in operating position, it will cut out and reset as soon as I release the lift button.
  • Posted 25 Aug 2021 09:55
  • By Josh_G
  • joined 25 Aug'21 - 2 messages
  • Washington, United States
The controller has detected a motor encoder fault. Need to verify wires from encoder to controller are good. If the connector at the controller is good, need new encoder. Verify 5 volts at encoder using ground wire at same location. This way you verify positive and negative wires. The other two wires or return to controller to say how fast and which direction the motor is turning. Also, check fuse two connection as they will fail. Good luck.
  • Posted 3 Sep 2021 05:04
  • By Fishmech
  • Virginia, United States
