stand up forklift. All functions work ,but tilt.
Model #20i-4D-R40TT. It is 4 wheel, but that doesn't matter, that lever works All controls work, Up/down/left/right/tire turner, ect.. BUT TILT. When the tilt lever is activated, it sounds like the hydraulics are trying to do their thing but, nothing happens. wondering if you could point me in the right direction? Kinda new to forklift troubleshooting. Any help would be appreciated.
  • Posted 12 Aug 2021 09:08
  • Modified 20 Aug 2021 09:33 by poster
  • By JacoVMN
  • joined 12 Aug'21 - 1 message
  • Wisconsin, United States
Most likely is the control wiring to the hydraulic solenoids out at the carriage.
The overmast cable (the one running through the mast channels), the cable that runs through the reach assembly ( h frame where reach rams mount) and the diode pack under the reach assy if it is equipped it should be if you have a 20I be careful of jumpers installed on the terminal strips if you are removing the wiring they are small pieces of steel that fall out after the screws are loose. Jumping power past the entire circuit can prove the wiring is faulty or not. Good luck. Don't chop your arms off.
  • Posted 23 Aug 2021 08:47
  • By stam
