C500 Y80 Engine
How do I find out what engine is in there?
Model is C500 Y80.. It looks like a continental, but what engine model?
I was told the year was 1975, serial is Y685-58-1213
And, where is a good place online to order a head gasket?
Thanks.
  • Posted 25 Jun 2021 07:00
  • Modified 25 Jun 2021 07:31 by poster
  • By henry
  • joined 6 Feb'21 - 4 messages
  • British Columbia, Canada
Ok, I got the head off.
Draining the coolant was weird, nothing came out of the block drain, even pulling it right out. I could see into the block and it was dry, but the head and the upper part of the block was full. Plugged somewhere maybe?
The other thing I noticed was a crack between the cylinders at a couple of the bolt holes. I remember reading somewhere that this is common.
How catasrophic is this?
https://photos.app.goo.gl/79aKHKL5LB8E4uhLA
Thanks.
  • Posted 17 Jul 2021 14:26
  • By henry
Thanks for the info!
Any ideas where I might find the engine model number tag? I can't seem to locate it.
Or, is there some way to look up the model by engine serial?
Thanks.
  • Posted 9 Jul 2021 13:50
  • Modified 12 Jul 2021 07:29 by poster
  • By henry
Looks Like it is a C500 Y 60. 1975 June model.
I am unable to find a model, but the SN on the engine should be 31844 (or at least it left the factory with that SN).
  • Posted 2 Jul 2021 02:32
  • By Jim_Dandy
  • joined 2 Jul'21 - 1 message
I have checked and the cylinder head gasket is available through Clark Organisation.
  • Posted 30 Jun 2021 18:11
  • By bertrand_b
  • joined 14 Apr'08 - 8 messages
  • Ile de France, France
Clark made use of the Continental L-Head engines, Fourcylinders models N56, NI62, Y69, Y91,Y112, F124, F135, F140, F162 and F163.
Six cylinder models F186, F209,F226, F227, F244, F245, M271, M290, M330, M363, B371, B427.
Normally an engine name plate is attached to the cylinder block, that would help identify model and serial number (wich could be helpful with ordering parts).
I have no expierence with ordering online parts, googled for continental flathead engine parts and get a lot of hits like continentalengineparts dot net. Should be a oiece of cake :)
  • Posted 25 Jun 2021 19:35
  • By Speedfreak
  • joined 24 May'18 - 103 messages
  • Niederlande, Netherlands
