Not moving and Lifting
Pls technicians I need help. Lindel e16c is not moving to both directions and not lifting as well. And is not showing any error. Pls what could be the cause??
  • Posted 28 Apr 2021 11:05
  • By Raone
  • joined 28 Apr'21 - 2 messages
  • Nigeria
Check seat switch
Seat belt switch if it has one
And also check the cabin switch under the cab when you shut the cab down the switch should close
Located next to where the steering column connects
  • Posted 6 May 2021 22:09
  • By Lindetechnz
  • joined 28 Apr'21 - 58 messages
  • New Zealand
Lindetechnz
Is it a 335 serial type? in emergency switch you have a small microswitch. If this not make contact you have problem. Check with multimeter or in diagnose software.
  • Posted 30 Apr 2021 16:05
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Thanks so much. Have checked that already and have even bypass it as well. But still giving the same issue.
  • Posted 30 Apr 2021 14:35
  • By Raone
  • Nigeria
Hello , do you know serial number? 335 type check seat switch , cabin switch first
  • Posted 28 Apr 2021 18:42
  • By tr_doctor
  • Netherlands
Regards
Michel Denis Michel Denis
Toyota 02-8FD25
Manitou M50-4
Toyota 02-8FD25
Manitou M50-4
Yale Lift Truck Technologies
