Axle master 20whe combilift no hydraulic fuctions
I have an electric aislemaster 20whe.The hydraulics and steering has stopped working. All fuses etc are ok. Checked contactor and is working. Traced wiring back to the board and i have no negative coming from the board to the hyd contactor coil. Any ideas?
  • Posted 19 Mar 2021 15:36
  • By Nick_Rocha
  • joined 19 Mar'21 - 1 message
  • Peru
Nk
Hi Nick,
If you can check that the controller has power to its self by checking the leds are flashing.
If you email Combilift Technical group they will support you, or go to the Combilift web site and select "Service&Parts" and then select "Contact Technical Support".
Hope this help you solve this problem and help with future support.
Thanks Richard
  • Posted 19 Mar 2021 20:43
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
