shuting off
I have a crown pc4500 shuts off when turning left cant figure out whats going on. any ideas
  • Posted 28 Jan 2021 05:46
  • By Art_V
  • joined 28 Jan'21 - 3 messages
  • Washington, United States
Art
No problem! good luck
  • Posted 29 Jan 2021 02:06
  • By Triggs
Ok ill do that and get back to you see if I find anything thanks for your help
  • Posted 28 Jan 2021 08:48
  • By Art_V
Art
Check the harness that goes from the x10 handle down into the steering "column"
I've had wires break due to the back and forth movement. Check continuity with the handle turned in the faulting position
  • Posted 28 Jan 2021 07:56
  • By Triggs
It just stops traveling power stays on. If I shut it off and on again it will run until I turn
  • Posted 28 Jan 2021 07:38
  • By Art_V
Art
All power shuts off? Or does just travel stop?
  • Posted 28 Jan 2021 07:19
  • By Triggs
SMV (Konecranes) 4632CC5
Crown RR5225-30TT321
