No Drive
Hey guys, got this NYK no drive, put truck in forward all contactors come and in reverse , reveerse contactors come but no drive either way Does anybody have any info or any suggestions Thanks Rich
  • Posted 28 Sep 2008 08:48
  • By rich_k
  • joined 30 Oct'07 - 108 messages
I don't know a whole lot about this truck. I know a few people have worked on it and yes it has been sitting. I don't know what they have done. Motors look good , contactors look good, switches are good, it has a control card in the accelerator box. lift and steering are good. tires are off the ground. I don't know where to get parts. I am having the accelerator card control checked right now. This could be a real fun one. If you have anymore info that would be great. Thanks Rich
  • Posted 30 Sep 2008 07:10
  • By rich_k
first, I always apologize to anyone with an NYK in the USA, and I guess I should for Canada too...do you have a good NYK parts source you could share with the rest of us?
First question, did this problem suddenly happen, (when changing directions?) or has this truck been sitting and you don't have any history? does lift work normally? does it have power steering that works correctly?
My first guesses, (and guesses are all they are at this point, I don't know which NYK control system version this model number uses, off the top of my head, but having directional contactors narrows down the possibilities) would be to check inside the Accel box for switches, and make sure they are operating correctly, and that the cam has not come loose from the shaft (I think there may be a set screw loose and the cam moved so that the wrong switches activate)
When you say "put truck in forward all contactors come" do _all_ the contactors coils energize at the same moment, (including high-speed/bypass and hydraulic pump) and does the same thing happen when you start from a disconnected battery and try rev. first?
Next question, do you know enough about electric motors and controllers to be able to figure out which is the bypass contactor, and does the drive motor run when you (jack the drive wheel off the ground and) manually close (both at same time) one of the directional contactors and the bypass contactor, and do you get the same results (but different direction of rotation) with the other directional contactor?
  • Posted 28 Sep 2008 22:57
  • Modified 28 Sep 2008 23:02 by poster
