material handling codes
i get A6-1 when i turn the key
and A6-2 and A6-5 when i pull the levers
no lift
f&r works fine
i only have the 5fbcu25 book
is this shorted hyd switches like in that manual?
any1 got this manual?
thanks
  • Posted 26 Sep 2008 12:43
  • By justinm
thanks man ill check that
it sounds like its the same as an A6 in a 5FBCU book just more detailed
  • Posted 28 Sep 2008 08:19
  • Modified 28 Sep 2008 11:11 by poster
  • By justinm
Hey Justinm, I have just got off the phone with a buddy who has the manual-A6-1 Lift switch #1 Short circuit A6-2- Lift #2 Abnormality- A6-5 Attachment switch abnormality- He suggested that you might have a pinched wire harness or faulty micro switches - remove and bench test micro switch - During start up the computer sees an open loop in the lift system, Automatic fault code. Hope this helps
  • Posted 26 Sep 2008 23:59
  • By Prentice
Enforcer FLBAXT25
Unicarriers FD80-2
