problem
hello, I recently had an accident with an efg 316 electric forklift.
driving backwards with the load a few meters in front of the ramp, I tried to stop, the reverse foot releasing the levers, which did not react, then pressed the forward levers to check if it blocked, the forklift still did not react. I tried to use the brake lever foot , which also did not react, then i hit the ramp. before i hit ramp when i drive all the diodes were lit on the console and the forklift beeped about an error and displayed error 021. After the impact, nothing worked, there was a need to restart with the key. before the failure everything was working, why was this error? why the forward / reverse levers and the brake stopped working. after restart forklift all work properly.
please help, I'm afraid to drive.
  • Posted 6 Oct 2020 23:04
  • By Tomasz_Orzol
  • joined 6 Oct'20 - 1 message
  • Poland
tomasz
the ones with mp1510 had this kind of problems when steering booster motor is starting to die out. its an armature current fault. when error happens again ,check on controller boards wich one is reporting fault.
  • Posted 10 Oct 2020 06:13
  • By PenTakl
  • joined 10 Oct'20 - 6 messages
  • Croatia
Crown WP302020
Maxlion FB25LI
