Code23
what does code 23 mean?
  • Posted 26 Sep 2008 00:18
  • By debbie_b
  • joined 26 Sep'08 - 1 message
Q1 should come in a kit with Rec 1 if not it's recommended that Rec 1 be replaced also. Also check the snubber resistors (the big gold ones beside Q1) the resistance should be 1 ohm each.
  • Posted 7 Dec 2008 03:40
  • By RayMaster
  • joined 30 Jun'08 - 6 messages
It is usually a bad Q-1 transistor. It is available in a kit part # 828-900-101. Just going by memory on the part#. There are a few tests that can be run in the on board diagnostics and then the Q-1 can be tested with a Fluke meter. Also look at the drive motor brushes and the comm. on the motor, if they are very worn or burnt it could cause the code. It is also recommended to replace the power card if the Q-1 is shorted. Good luck.
  • Posted 30 Sep 2008 13:15
  • By kurt_k
  • joined 16 Sep'08 - 3 messages
  • Wisconsin, United States
Open detected in armature circuit- Check Fuse #5 - Visually inspect 'B' contact's tips for weld condition ( if by pass is equipped)
  • Posted 26 Sep 2008 02:07
  • By Prentice
Esie Cortez Esie Cortez
Yale Lift Truck Technologies
Oxford Ct, United States
