No throttle
Truck starts right up but won't throttle,
Cleaned the throttle body and still nothing.
Took a Throttle sensor off a working truck same model and worked great.
Purchased a new sensor assy from Toyota installed it worked for 10 seconds and now I'm back to no throttle. Running out of ideas?
  • Posted 2 Sep 2020 06:32
  • Modified 2 Sep 2020 06:37 by poster
  • By C_GILLARD
  • joined 2 Sep'20 - 3 messages
No throttle in any position.
  • Posted 8 Sep 2020 22:10
  • By C_GILLARD
Does it have throttle in neutral ? I've had one before that had throttle in neutral and no throttle in gear had issue with wiring going to the mast height switch
  • Posted 4 Sep 2020 08:43
  • By Jordanco888
  • joined 31 Mar'17 - 3 messages
  • Connecticut, United States
No codes. I'll run through the other suggestions. Thanks
  • Posted 3 Sep 2020 23:38
  • By C_GILLARD
Do you have the plug in analyzer or is it the onboard one ? Codes? Corrosion on governor plug? Your analyzer will show throttle angle and should be 5.0 to 5.5. If the throttle sensor is out of range, again it will code out. Check fuses for ECU's. Do a voltage test thru fuse or in doubt replace the 3. Your dvom isn't always accurate to pick up a shorted fuse. Had one the other day showed.04 ohms. But 1.7 volts only to ECU.
  • Posted 3 Sep 2020 21:11
  • By ron_k
  • joined 2 Apr'15 - 122 messages
  • North Dakota, United States
4kliftman
Philadelphia, United States
Prospect CT, United States
Davenport, IA, United States
Dayton OH/Cincinnati OH, United States
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Toyota 8FGCU25
Flesherton, Ontario, Canada
USD1
Toyota 8FGCU25
