Code GD
Had a unit with that code and the steer motor encoder bearing failed the test shown it was not counting. Eventually found out it was not the steer encoder bearing but the steer AMP was the issue. Was told by an experienced tech to always change the steer amp first before a steer encoder bearing, its easier and faster.
  • Posted 7 Aug 2020 07:16
  • By Mark_Stokes
  • joined 1 Feb'20 - 11 messages
  • Colorado, United States
GD-open detected in steer motor encoder.
Did you take it out and check to see if the hardware came of and encoder is loose. Maybe just needs to tighten.
  • Posted 21 Aug 2020 01:58
  • By selftapper
  • joined 19 Feb'15 - 5 messages
Linde Material Handling
SMV (Konecranes) 4531CC5
Crown RR5225-30TT321
