DANA TE27 - APC200 Controller error 34.00
Hello,
I have a DANA TE27 with controller APC200 install on a Linde 09 Model: Rs46T FL012092. The APC 200 controller initially showed a the failure 93.1 = failed initialization of essential controller data in flash memory.
Following an upgrade of the firmware into the APC - The controller now shows a failure code 34:00, 34.04 and so on.
Does someone know this failure and what I can check/do ?
As per the fault code, it is mentioned that the wrong firmware is flashed into the APC200 and that I need to replace the APC 200, hydraulic I/o, engine control module.
Does anyone know if their are any alternatives ? why cant I just reload the correct firmware into the APC200
Thanks for the assistance
Regards
Steve
  • Posted 7 Jul 2020 17:02
  • Modified 10 Jul 2020 20:06 by poster
  • By Steve_Tanner
  • joined 7 Jul'20 - 1 message
  • Mauritius
Muncie, IN, United States
